Is this how you did it.
3/16 BB in the regulator (low fuel pressure) Should be 60lbs to 85lbs
Regulator is the 19 mm brass bolt, on the right side of your fuel filter housing. Unscrew the bolt, pull out the spring, pull out the housing with a magnet, put the bb inside the housing were the spring goes, put the housing back, put the spring back in and put the bolt back in, just make sure the little nipple on the bolt goes in the center of the spring and tighten it up.
Explaination of how to put the BB in the fuel regulator little better and clean the regulater screen
Get a regular BB, wait till your engine cools some and take the black cover off the top of your motor. This requires a 1/2 in deep socket and ratchet. There are 3 nuts on the cover. Next look at your fuel filter bowl and just to the right at the front will be a brass 19 mm plug on the fuel regulator. You will want to place a rag below this plug in case you drop anything. Next, remove the plug and place it on the top of your fuel filter housing using a 19 mm socket or wrench. You will now see a little spring that is exposed. Take a pair of small needle nose pliers and grasp the spring and pull it out of the regulator. Place it by your plug noting the way it came out. You will want to go back in with the same end that came out of the regulator side. Next, take a pencil tip magnet and be sure everything is clean on the magnet (we don't want metal shavings in there)....place the tip of the magnet in the hole and it will pull out the little tri-angular plunger that regulates the fuel pressure. Take the plunger off your magnet and look at the end of it. The end that has the hole is where you want to place the ball bearing. Take your ball bearing and drop it in the hole. When I did it the ball just fell in the hole. Take a little punch and make sure that it seats in the counter bore of the plunger. Not with a hammer, just pushing on it by hand will suffice. Next, make sure everything is clean and place the spring back in the plunger the way it came out. Place the plunger back into the regulator. The tri-angular shape will "FIT" into it's respected groove. DO NOT FORCE IT. Turn the plunger until it slides right in. Next, take the 19 mm plug and coat the o-ring with some oil or light grease so you will not damage the o-ring. Next, note the nipple on the end of the plug where the spring is centered. Be sure to get that nipple into the hole on the end of the spring or you will bend the spring and you have trouble. Push the plug toward the threads in the housing as it will be harder to push now, and screw your plug back into the regulator. DO NOT CROSS THREAD THE PLUG. Next tighten the plug back down snug. DO NOT OVERTIGHTEN.
Fuel Regulator Screen Cleaning
The fix is simple. Take off the cover over the fuel filter, 1/2 socket does the job. Place a towel or shop rag under the fuel regulator!!!! There are two 10 mm bolts just to the right of the fuel filter, take both out making sure you put them back the way they came out. Gently pry the fuel regulator away from the fuel filter housing, making sure you don't drop the o-ring. You will see a small screen about 1/4 inch. Using a small screwdriver or q-tip w.out the cotton ball on the end, wipe the screen and then put everything back together. The material you get off the screen I have been told is from o-rings. The fix will only take 15 to 20 minutes. If you find the regulator is blocked, clean it, install new fuel filter, and it shouldn't need to be done again for 12 months.
Replace your black cover and you are ready for a test drive to see if you made any difference. You should definitely feel a difference in throttle response. You will actually have more boost pressure.
