Fuel pressure issue
Dieselpowerking
Lewiston, idaho
Alright guys I installed a facet lift pump 40222 got it all put together but one problem is I'm losing all fuel pressure at full throttle any help? This truck has to be towing Saturday morning. So I'm kinda in a rush.
genscripter
Inglewood, CA
Alright guys I installed a facet lift pump 40222 got it all put together but one problem is I'm losing all fuel pressure at full throttle any help? .
Do you have a reliable fuel pressure gauge? If yes, then what pressure are you getting at idle and what pressure is it getting down to at WOT?
@Thewespaul is right. Sounds like a filter issue. That duralift e-pump should be pushing plenty of fuel to your IP.
Dieselpowerking
Lewiston, idaho
Pressure get down to 1 almost zero with full throttle at idle it had about 8 psi maybe a little more
chillman88
Central NY
Wes, what gauge should be run to the fuel pump and what size fuse? I will be doing this to mine tomorrow as well. Mine is a different pump back by the FSV but same principal.
I’d start with a 15 amp fuse, and I really like autometer gauges, the ultralight series being my favorite. They have an electric fuel pressure gauge that I use for pumps
Poway, CA
The only way the relay would be 'causing' your battery to drain is if you wired the 'switch' power (the one that is telling the relay to turn on), to a constant power source. Make sure it's tied to a switched 12V source, i.e. something that's only on when the ignition is on.
Mike
Tyler9828
