EMD_DRIVER
Say what?!?!
I got my regulated return installed in the 99, but I am now chasing down a fuel pressure drop. I have my FP gauge sending unit installed with the return line, before it goes into the regulator. When I did my regulated return, I used 1/4" steel line.
Once the truck warms up, my fuel pressure will drop from 60PSI and go down to 30PSI under moderate throttle. If I hold it at WOT, I can make it drop to 10PSI. If I do that, it's only for a second. I do not want to starve my injectors. I thought maybe my OEM pump may have just been having trouble keeping up with demand, so I plumbed-in my in-bed tank to the factory fuel system. My in-bed tank has a Holley blue mounted to the side of it and I am now pumping fuel into the intake side of the factory pump. My pressure drop has not changed, with this setup.
The FP gauge I am using, isn't the most expensive one I could find, but seems to work well. I am almost tempted to try running a mechanical gauge to the cowl, so I can see what it would say. It's not the easiest thing to do and something I would do if I had to.
Worked on it for a while today... I found a kink in the line that goes up the front of the block.. Ended up having to replace the line, from the fuel pump to the fuel bowl. No change in fuel pressure performance. Took the truck, to pick my son up from soccer practice and fuel pressure was bouncing from 0-65PSI.. I had no idea what was going on..
Got it home (Barely) and commenced to re-wire the fuel pump. It is no longer controlled by the PCM (Hope it doesn't throw any codes) but is now controlled by a dedicated fuel pump relay, getting power directly from the battery. When I turned the key on, I noticed the pressure needle bouncing.. Without the engine even running. I listened to the fuel pump and it was making all kinds of noise. It would build pressure and then let most of it off, it would then build and drop pressure... It just kept doing that.
I checked for leaks and found none. I also checked the regulator and it's also working fine. I'm assuming that the fuel pump I just put on two weeks ago, is also bad. I have another used one and will install it in the morning.. We'll see what happens then!
