fuel line question
Steve Olkowski
Trying to get a bracket that PO super welded so I could install air bags, I managed to melt a place in rear fuel line. Is there a way to couple it back, do I need to replace? Trying to locate a source for the line if anyone knows one. Thanks, Steve
Just replace it. You can get new quick disconnects from the parts store. In the help section.
Steve Olkowski
Would love to find replacements for it. You think in the meantime I could couple with brass nipples?
Macrobb
North Idaho
If it's that nylon plastic line, I've used rubber fuel hose and hose clamps myself.
If it fits and doesn't leak, it's fine. Remember, it's not under any pressure - supply line is under vacuum, return should be less than 1 psi.
The only down side to fuel hose is that it seems to start getting hard after about 10 years, after 15-20 it's probably going to need to be replaced...
Easy fix is replace with fuel rated line.The supply is 3/8 diameter and the return is 5/16 diameter.Hose clamps and your golden.
crash-harris
Breaker! Breaker!
Chillicothe, OH
If you're talking about the nylon hardlines...
In the Doorman help section at autozone, there are brass barb nipples in different sizes that have hard cut barbs on them like push-lok barb fittings. Get the correct size and a couple of injection line clamps, heat one end of hose at a time, just enough to get soft, and press the barb into the line, then let it cool around it and tighten the clamp down on it.
Alleycat
