So I upgraded my 6.9 to the 7.3 filter head and return system, using 1/4" clear fuel line on injector and IP returns, along with 3/8" clear IP feed line to eliminate all olives, to be able to track air intrusion and system function, and to get rid of the seperate fuel/water seperator. I also cut down the lift pump to filter head hard line just below the factory 6.9 fuel heater and have 3/8" rubber fuel line up to the filter.
I had no issues for several days after I installed everything, then all of a sudden I had the infamous start then stall air intrusion issue. With the clear fuel line it was instantly apparent where the air was coming from because i could see bubbles being drawn in. The clear fuel line was leaking at the barb fitting on the outlet of the filter head. Even with a clamp on it, it wouldn't seal, as if the ID was too large for the barb. So I replaced it today with regular black rubber fuel line and it fit much more snug. After finally getting all the air out of the system and firing it up, I let it run for about 20 min while I was checking for leaks, purged the filter head through the schrader valve, revving it here and there, and all seemed well.
When I shut it off from the engine bay, I watched as air just flooded the return lines from the filter head return! And I could hear gurgling down by the lift pump. Pump is new, no leaks from any of the lines or outlet compression fitting. I immediately started it back up and let the air purge out until it was running smoothly, then shut it down again. Nothing. No air intrusion, small bubbles in return lines stayed still, showing the fuel wasn't moving.
So fuel can drain back through the lift pump, I'm guessing if it's stopped in the middle of its cycle? Is there a feed line check valve in the system? I thought I saw a mention of one before, but I looked and didn't locate one. If there is, I'm guessing it's irony that as soon as I mess with the fuel system, problems start to arise, as I didn't have any issues before.
Thanks in advance!
Thanks in advance!
