John Deere
I have replaced the return lines and tees, replaced all other rubber hoses, shrader valve, lift pump, and the ball check valve on the injection pump. I also removed my tank selector valve and checked it to make sure it is working properly. I have no fuel leaks anywhere. And yet my pickup still has to be reprimed after sitting for @6-8 hrs.
Any ideas as to check next. Is it possible that a injector could be the cause of it bleeding off, how about the brass restrictor valve on the fuel filter housing, it's not a check vavle as far as I understand so it makes no sense as to it being a culprit, but I could be wrong.
I am at my wit's end on this, if you have any ideas, I'd love to hear them. And this is on my '88.
