FS: Doug Nash DNE2 overdrive box
FarmerFrank
Blairsville, Pa
Currently bolted on a 2wd c6 New shift motor and switch. Come with everything needed to bolt onto c6. If your truck is an extended cab I'll send the shorter shaft to the carrier bearing. I'll also send it with a fresh bottle of 75w90 syn oil. I think I still have the original wiring but it's too easy to make your own.
$600 shipped OBO
Thanks
Frank
dunk
Dunce
NJ
Will this bolt on the back of a NP208, BW1356 (fixed yoke), or NP205? Would be interested in a double overdrive.
The Warden
MiB Impersonator
Fog Bless Pacifica (CA)
I'm pretty sure it won't. On 4x4 applications, these were meant to bolt between the transmission and the transfer case, moving the transfer case aft.
I don't know how practical it is to convert a DNE2 box meant for a 2 wheel drive to a 4x4 application; if it was practical, I might be interested just for spare parts...
Hmmm only if you'd plan to build a super cool 2wd hot rod idi..... $500 would put this on your doorstep........
yup, i do, i have everything but the front axle.
however, im running a ZF5, i wont need any more OD.
its a hotrod not a freeway cruiser :D
mitsu tractor
