Front airbags?
Exekiel69
I have the stock 89 springs on My 93 with the Dana 60 and I'd like to make it firmer with out adding hight to it. I have looked a some kits but I really don't have any feedback on them, does anyone use have air bags on their truck front springs? What brand would be best and any any on where is the best deal?
Thanks.
Go to any RV supply store. They have or will order air bags for the front coil springs. Easy to install. I had an RV service for 15 yrs. and installed lots of them.
Exekiel69
I have leaf springs on the Dana60, do they work the same?
I've installed the tubes in coil springs before and they worked ok for a simple tube.
Double-S-Diesel
parts seller
derry pa
EZ I had air lift on my 00 truck for 3 yrs, then took them off, they sat around until this year and I put them on my 03.
they have a lifetime warranty.
currently looking at a set of fronts for the 03 now, so I can use them to level the truck camper out.
Exekiel69
I found two kits on ebay
this one http://www.ebay.com/itm/Firestone-2...:1995|Model:F-350&hash=item20c48491d9&vxp=mtr
and this one http://www.ebay.com/itm/Air-Lift-59...:1995|Model:F-350&hash=item4d034dd741&vxp=mtr
I look at the front springs and they look to be not enough for a 4wd, I know they are negative springs, I still want to help the front suspension. I need to read more about them, I still don't know which one I should go with air bags or air lift. I do know I don't want to lift the truck even more, the 4wd conversion raised more than it needs but I want to help it stay at the current hight even when loaded.
Thanks.
JU57US
