oregon-mike
Hey all,
Working on Rose's 99 cc dually again. Had charging problems, replaced the alternator today (man, all vehicles should be as easy as these ). Decided to check her key off current flow to see if there was something else going on. I'm getting 360mA after the initial bump up to almost an amp. I went through and pulled every single visible fuse & relay in the engine compartment & under the dash. It never dropped below 250mA. I pulled several of the fuses that let it drop to 250mA at the same time and the current stayed the same.
Can somebody with a meter check their Powerstroke to see what kind of flow you're getting? In quick searching on the net it looks like we ought to be under 100mA, under 25 ideally, but I'd like some confirmation before tearing any further into this thing.
Has anybody seen anything like this if it's obscenely large on the current draw? Am I missing a fusebox somewhere
Thanks all,
Mike
Thanks all,
Mike
