73idi88f350
found the complete thing minus the master cylinder and an auto pedal i need manual.. res 2 lines 1 rubber return already fitted other then it was on 460 gaser just under 50 bucks! other then looking old it looked bone dry.. one line looked recent new other was homemade with a section of hydraulic hose and the factory molded return looks good!
so found this yesterday (Saturday) got it installed today(Sunday) to fix the pedal prob i honed out the wholes in the firewall that held the hydroboost.. (in my job not quite enough) and honed the holes in the orig master. the spread just wasn't enough.
i used my pump and swapped the res, that was really easy! glade i grabbed the fitting that came out the side because it looked different then the one on my 88 pump.
everything else was plug and play like it came off.. did a few painting and everything got cleaned that went on
heres a few pics (fyi i do have 2inch body lift)
