Ford valves, springs and such for 289/302/351 Heads
Worstenemy453
King George, Va
This stuff was pulled from a set of heads i had. Everything was mounted but never used. Heads were never mounted. All the parts will be cleaned down and sealed up before they get shipped. They should work in most early Ford V8 heads for 289/302/351.
THE STUDS IN THE PICTURE ARE NOT INCLUDED. I already sold them.
- Manley 42125 Guide plates - I believe these are $20 or $30 for the set, but i cant find them available anymore.
- Sealed Power V1961, 1.46 Exhaust Valves - $10.58 a piece new.
- Sealed Power V1932, 1.78 Intake Valves - $7.00 a piece new.
- Set of Crane springs, the set is stiffer than stock but i dont know the part numbers.
Pictures are in the auction.
http://cgi.ebay.com/ebaymotors/ws/e...27427&ssPageName=STRK:MESELX:IT#ht_500wt_1182
Ill end it early for $75.00 Shipped.
idiabuse
Princeton Fl
those valve springs are the same application I used on my 7.3IDI build
about 115LBS on the seat and about 285lbs open
I thought they replace the OEM springs in our trucks perfectly when set at the correct IDI installed height.
Javier
Worstenemy453
King George, Va
Javier
i wish someone would buy all this lol
