rockbender
Does anyone have any experience using a flexible intake tube/pipe between the air filter and turbo? On a van with a Banks turbo you have to snake around the fuel filter and then mount the filter right above the AC compressor. Banks has some sort of flexible tube in its kit, but I'm not sure what it is made out of (if I had one, I wouldn't have a problem!). I think I can build an ABS or PVC intake with a few fittings, but was thinking of using 3" semi-rigid/flexible aluminum duct (think dryer vent, but not the kind with just a spring and foil) as at least a temporary connection. The material bends nicely and is pretty stiff, but if you squeeze hard enough you could put a dent in it. I guess I am having this nightmare vision of a vacuum causing this pipe to collapse and just wanted to see if anyone has used it successfully before I get too far from home with it.
As far as the rigid pipe goes, is there a preference between ABS or PVC?
