Double-S-Diesel
parts seller
got a 95 with low miles, unfortuneatly it is a 1 ton dump with a plow and salt spreader.
ran and put away dirty, so much rust and corosion that the transfer case rotted away.
any how I need to remove the pass side manifold to put a gasket in it.
The nice 13mm headed bolts are rusted dow to about 8-12 mm.
had luck on the last one with the inverted ezouts, .
problem on this one is the bolts beng corroded to the manifold vrs the threads bieng corroded.
any tips, or ideas appreciated.
Nick
Nick
