jrisingmoon
What are the possible causes for excessive blowby? Worn piston rings? Trying to figure out what all is in store for me when I pull the heads off and replace the gaskets.
Also, if it is the piston rings, will I be able to tell which piston's rings are shot or will ALL of the piston rings need to be replaced?
I'll compression test it in the next few days and give a heads up later...
