johnnyb1
Bear with me everybody. I've never changed IP before. PO took off pump,cover,and gear!! I pulled #1 glow plug,turned mtr. over until I heard compression blow out. Then looked at harm. balancer. There are 2 timing indicators on bracket. Lower one has a line with "0" I assume this is TDC Top one has no marking by it. Chilton manual 4,5,or 6* ATDC. The mark on balancer is at top indicator. Does this sound like I've got it? Are there any links out there that may have better pictures? Chilton isn't really showing me what I want. I'm trying to avoid pulling front cover if possible. As always I appreciate any info
