engine rpm
turbo elk
Vancouver, Wa.
OK this is stupid... but I have a hard time finding my way around this web site on my phone..can anyone tell me the high idle RPM for my '91 idi? Thanks.
900 is about the best from al what I have found. Some like it higher and some lower...
To adjust the fast idle get a 1/4 inch drive wratchet and socket. Find the idle solenoid brass plunger. Turn it out till you like the setting. Caution... Its a fine thread so its going to take severl turns. Many times just loosening the barcket its mounted to and moving it towards the firewall gives enough adjustment to increase the rpm... Thos 2 bolt heads are 7/16 hex...
Devon Harley
San Diego
If using high idle for long periods of time 1500-2000 is where you wanna be I run about 1000-1100
