engine pics?
dieseldummy
Lost in time
CO
Hey, any of you IDI guys have pics of a 6.9 or 7.3 in various states of dissassembly? I'm looking for some pics of the head/injector region. A nudge in the right direction would be greatly appreciated...:thanks:
Justin
argve
Resident Fruitcake
Gwynneville, Indiana
I'll post some when I get home, I got tons of photo's of The Enterprise's internals... I even got some close ups somewhere (I don't think I deleted them) of the heads way back when I put my extra set of heads up for sale (like 4 years ago).
argve
Resident Fruitcake
Ok here is one that I saved, I actually deleted the others. We will try this again. Too large just a minute ago...
argve
Resident Fruitcake
also >>> Click Here <<< for more photo's... if ya need more just ask. I was looking for some of looking down the injector bore but it seems I did not take a photo of what the injector "sees"
troutwest66
Ricer-Roni The IDI Treat
Post Falls, Idaho
Say, Justin, you wouldn't be trying to sneak a REAL diesel engine in that bowtie of yours, are you?;) ;) :D Noticed there isn't much action in the 6.5 forum. Thought I'd give you a little good-natured IDI ribbing.:) Are you working on a 7.3 project? If so we'd love to hear about it.:cool
Freight_Train
Traitor to the brotherhood
Gadsden,Al
hmmmm,Now where have I seen that head before..........hmmmm.....Looks firmiliar......Blue IDI head.....hmmmmm
dieseldummy
Lost in time
CO
Acctually I was thinking about crosbreeding some parts. Like 7.3 pistons and injectors in a 6.5 block and heads. Your guys' injectors are longer than the 6.5's and the 7.3 pistons have a shorter compression height. In theory a nearly direct injected 6.5/7.3 could be born. I was trying to get some pics to see how everyting goes together in a Ford so I could ponder putting stuff in my Chevy...
dieseldummy
Lost in time
CO
I'm not sure of that yet, haven't got that far in my search for specs. I do know that the piston pin in a regular 6.9/7.3 is .1104 smaller than a 6.2/6.5. The factory turbo models are bigger however, not sure how much yet. If anyone has any specs. for internals that would be great as well. Rod journal diameter, rod lenght, physical injector dimensions, and fuel rate are a few that I need to know...
Freight_Train
Gadsden,Al
well,Here are the specs from the Hayne's manual that I grabbed outta the Enterprise tonight.
Bore Stroke of 7.3L 4.11x4.11
Cylinder Bores of 7.3L 1 thru 6 4.1100-4.1120
Cylinder Bores of 7.3L 7 and 8 4.1096-4.1103
Piston Diameters 1 thru 6 4.10350-4.10400
Piston Diameters 7 and 8 doesn't give anything....DUH Haynes!
Crank Main Journal 3.1228-3.1236
Connecting Rod Journals 2.4980-2.4990
Freight_Train
Gadsden,Al
oh duh....It even has the Chebby stuff in there....forgot!Here is what is listed for the 6.5L
Bore 4.057-4.058
Pistons-Selective Fit(?!?!?!That had to be a [CENSORED-BY ME] on the assembly line!)
Crank Main Journals 1 thru 4 (82-93)2.9495-2.9504
5 (82-93) 2.9492-2.9502
1 thru 4 (94 and later) 2.9517-2.9520
5 (94 and later) 2.9515-2.9518
Connecting Rod Journals (82-93) 2.3982-2.3991
(94 and later) 2.399-2.401
and here is the 6.9L stuff
Bore and stroke 4.00x4.18
Bore 3.9995-4.0015
Pistons 3.9935-3.9955
Crank Mains 3.1228-3.1236
dieseldummy
Lost in time
CO
Cool, all's I've got is a chiltons manual for 89-98 chevy pickups in general. Is the haynes worth the $?
