My 1991 7.3 idi is making a rod knock sounding noise when cold but goes away once at full temp. I am running 100% wmo in the truck filtered to 10 micron through a huge filter. I can only hear the noise under the truck and near the drivers door. The noise is most noticeable at the drivers rear of the cab. The truck has a smf conversion, with a zf5 manual conversion. The truck has lots of power for an N/A, and reads in the middle for oil pressure on the stock guage at all times. I have also just rebuilt the heads with all new guides, and seals. Could this be an injector? When warm it doesnt smoke but when cold it smokes blue good since its on wmo. What would piston slap or rod knock be like? Thanks.
