I have an 1991 7.3. I just put new injectors in it, and a new return line kit from a good diesel injection shop. I am also running 50% used oil. After I had completed installing injectors and return line kit, I washed the engine out. I cleaned up my shop, and came back to start it about 30 mins after washing engine. The engine had already been fired since installing the injectors. The glow plugs were all immersed in water so I didn't use them, and the truck didn't start. I went and grabbed a can of brake clean and sprayed a bit in the intake. I cranked it over and it started up and ran at 650 rpm with a horrible loud knocking noise from 1 or 2 cylinders. The knocking noise lasted for 2-3 seconds. Now I have a vibration at 2000 rpms and above, could have I bent a rod or broke the crank? I didnt use the glows to start the engine since the last time I had washed my engine out, all my glow plugs shorted out and blew out, due to being immersed in water. Thanks.
