My inline fuse continues to blow but only when I start the engine. My main engine wire harness burned most of the end where the power to the glowplug is.so I bypassed that with a much larger cable. then the fuseable link feeding the filter head, the fast idle, the fuel shutoff and the cold advance got burned at the plug so I installed the inline 20 amp fuse. Well that continues to blow on startup. Its the red wire with the yellow tracer. What else does it feed? I suspect it feeds some power to a circuit on the solid state glowplug controller but can't tell for sure. May have to cut the harness cover and look for issues. But would rather know what is fed by this wire. Thanks guys for helping. I'm not very good on electrical issues. Especialy when they happen at random.
