Pino2234
This may be pretty complicated so I'll try to be clear.
This 6.2 is in an 82 chevy but it may be a newer 6.2 not sure the yet.
The injection pump has an orange wire that gives the solenoid 12 volts, so the problem is when I turn the key forward nothing happens
I unplugged tv orange wire and jumped 12 volts directly from the battery to the injection pump (where the orange wire plugged in) and the ip solenoid clicked so know it's getting 12v. But it won't start. So I plugged the orange wire back in and put 12 Volts ontop of the orange wire and everything turned on (the key buzzer, the ip clicked, and was able to start it).
I started it and it ran fine. I took the 12 volts off and left the orange wire and it stayed running.
Wats going on?
Wats going on?
