BioFarmer93
OPEC Hater
X2 on the bad ground... What got me to thinking was when you said that it wouldn't jump from your bosses truck, and the lights go to nothing when you turn the key. I seem to remember these particular symptoms... If it was me, I'd unhook both batteries and charge them while I checked the electrical integrity of all my cables and connections at both ends. When I put it back together I would use some electricians NOALOX anti-oxidation cream from the hardware store or H-D on everything that passes electricity from one surface to another.. Just before you make that final connection of the cable to the positive terminal, stick the pos probe of your volt meter on the pos post of the battery and the neg probe onto the positive terminal of the cable. It should show zero volts UNLESS you have a clock that's always on or a radio with a memory function that is always pulling a little power. If you have an ampmeter then measure between those same two places, for a clock and radio together the draw should be much less than one amp. Best of luck to you!
