Dyno Time!
funnyman06
Coventry, RI
So tomorrow night I am going to put the truck on the brand new rollers here at school. When I was talking to my buddy who runs it, he said that It should be able to pickup my RPMs so I can get HP and Torque. I am definitely going to be taking video and pictures! Ill be very happy if im over 170 RWHP and 300ft/lbs.
rhkcommander
Oregon
From what you got in your signature you oughta do decent! How good of shape is the injection pump?
funnyman06
Coventry, RI
The pump is in decent shape, I believe it has about 50K on it so its not fresh but its not awful either. I have a newer pump that i want to through on it, but I haven't had the time or the tools to time it.
funnyman06
Coventry, RI
Well I have good news and I have some slightly depressing news.
Good news: Did the headlight relay mod and it made a HUGE difference in how bright my headlights are :) Cost me about 45 bucks all in all and is worth every penny.
Bad news: Got the truck on the dyno, and Ill work on getting the sheet up tonight. But the truck made 122.4HP and 239.6 ft/lbs. HP pretty much fell flat after 2500 rpms, but I was making between 5 and 10 lbs of boost.
Also though, I have not turned the fuel up at all on the truck, so if no one has ever messed with the pump setting I think these numbers make sense for about 175 Flywheel HP.
I plan on turning up the pump and getting it back on the dyno in Jan or Feb.
Edit: Here is the dyno sheet for the truck.
funnyman06
Coventry, RI
what does a non turbo truck wheel dyno at?
here are the results from I believe the last Rally
Name - Horsepower - Torque in ft/lbs
Non turbo results
John Herbert 143.9 261.3
Marnin Gehman 137.4 257.1
Heath Sutton 123.2 218.7
Matthias Agne 108.8 229.1
Average Horsepower of a normally aspirated stock IDI.... 128.3
Average Torque of a normally aspirated stock IDI... 241.55
Turbo results
Heath Sutton- DPS inj 185.1 404.0
Heath Sutton MM's 178.7 387.9
Joe Perry 172.5 313.6
Suzi Agne 151.9 284.2
Steve Reitner 150.0 300.3
Chris Barber 148.7 278.8
Jared Witmer 136.0 304.1
funnyman06
Coventry, RI
Even more reason for me to believe the pump is at stock fuel settings. Time to turn it up 2 flats haha
ocnorb
IDIT
Wasatch Front
Oh yeah, turn it up!!
My truck doesn't really start pulling until it gets over 10 psi.
I am curious about the rpm signal. How did you go about getting a signal that the dyno liked?
funnyman06
Coventry, RI
haha, well they attached a white sticker on my crank pulley and had an optical sensor looking for it. It was really interesting to watch my buddy set it all up.
Sw1tchfoot
USA
So do have the pump at N/A settings with the Banks Turbo? Turn it up some and you ought to notice a nice increase.
funnyman06
Coventry, RI
This was the pump that was on the truck when I bought it. I used to think it was turned up a little because i could get it to smoke pretty good N/A. But now after the dyno run I'm guessing that its actually at the stock settings. I plan on turning up the fuel on Friday if i get a chance. I don't have the tools to turn the engine over by hand at my apartment so i need to get it into the shop at school.
ealiaga12
