bike-maker
I've heard of those 4way valves having issues with getting stoved up and breaking. I ran two of the 3 way valves for that reason, and because the 3way valves are cheaper/much more common. Also allows you to transfer fuel between the two tanks, which has come in really handy a few times. No issues with the Carter pump pulling fuel from the tank clear through filters and the valves. As long as it's mounted lower than the tanks (mine is on the frame rail next to the transfer case), you should be fine.
