Dreaded headlight switch color codes?
RavenTBK
Apalachicola Natl Forest
My GoogleFu, on this topic, seems weak, and I cannot find the information I seek. ;)
Basically, anybody have a simple list as to what colors are connected to what with regards to the headlight switch?
I've got one thats partially melted out of its insulation, and I'd like to know where it goes before I start to tear apart the existing harness and find out it goes somewhere else.
Try this diagram.
wh1056
Julian, PA
Not sure if this will help, but I just bought the connector/pigtail at Advance and installed it last weekend.
Made in Taiwan, but less than $10:
Wire color/orientation:
Mine was just a little crispy:
RavenTBK
Try this diagram.
<snip>
Thats exactly what I needed. It has clear designations for wire color leaving the headlight switch. I found many similar showing just connections, but lacking the colors. At least now I know where my target wires connect to, and can simply replace them rather than cutting it all out of the loom.
Nanohawk
