Shawn MacAnanny
While installing the new injectors and pump I am removing the factory fuel filter and replacing the mechanical pump and filter with a cat pump and 5 micron filter under the frame. I already had the braided stainless line made up to directly connect to the injection pump. I know there is an air vent on top of the fuel filter to bleed air and return fuel, and there is a a return on the injection pump. So being I am directly connecting to the injection pump if air were ever to get into the line it would have to go through injection pump to get out. I know if changing the filter I can have key on and crack line to bleed without cranking but is the ip designed to allow fuel to go through it without it rotating? That'd eliminate any air since it an electric pump and the waiting 10 seconds before glow plugs turned off would purge anthything.
