PwrSmoke
IAT (Intake Air Temp) has significant effect on power with NA diesels. The "Magic Number" is 90F. After that, you see power start to drop. I had this great chart that showed approximately by how much in ten degree increments. Can't find it now but IIRC it was about a 2 percent drop per every 10 degrees. I tested this with my old 6.2L GM on a dyno by artificially heating the intake air. With 155 degrtee air, power dropped from 94 at the rear wheels to 79, which was an average of 3-4 tests. Below is the a part of the chart from the 9-part buildup article I did for Four Wheeler back in the '90s. The formatting didn't hold perfectly but you can get the idea. Bear in mind, these dyno tests were done at 5,000 feet in Denver, so there was an automatic drop in power due to altitude but all the tests were done there. Since the 6.2L has the same basic injection system and combustion chamber type as the Ford IDI, take note of the effects of various things on power besides IAT. The percentages should roughly hold for the 6.9/7.3L. I remember spending about a week in the dyno lab to get these numbers and it was very cold out. To keep IAT below 90, I had to run with the shop doors open and about froze my ass.
[/SIZE]
Code:
[[SIZE=1][B]Dyno Test Results[/B]
[B]Mustang 5000 Chassis Dyno[/B]
[B]Condition Power Torque* Intake Temp % HP Increase[/B]
1-100% stock, as purchased 94hp 272 lbs-ft 88 degrees 0
2-Advance pump timing 3 degrees 102.5 287 lbs-ft 90.2 degrees 6.8
3-Advance pump timing 6 degrees 100.4 285 lbs-ft 87.5 degrees 4.7
4-Intake air temp increased 87hp 233 lbs-ft 115 degrees -9
5-Intake air temp increased 84hp 218 lbs-ft 134.6 degrees -12
6-Intake air temp increased 79hp 207 lbs-ft 155 degrees -21
7-Rebuild injection pump and
injectors [B]106hp**[/B] 297 lbs-ft 5 degrees 13
8-Add K&N air filter element 108hp 301 lbs-ft 89 degrees 2
9-Eliminate Air cleaner 106 hp 300 lbs-ft 95.3 degrees 0
10-Remove EGR valve 105hp 301 lbs-ft 91 degrees -1
11-Add Stanadyne Performance
Formula to fuel [B]114hp[/B] 329 lbs-ft 84 degrees
* Note that on a chassis dyno, gearing multiplies engine torque readings somewhat.
** New baseline for rest of tests.
