Dana 50 TTB torque specs
yeeyee722
GA
Anyone have the torque specs for the front leaf spring bushings on a dana 50 (both for the bushings and the shackle that bolts to the frame)? Got her apart and realized that was probably important for getting it back together
1993 F-250 7.3 IDI
aggiediesel01
Houston, TX
2 grunts and a fart. That is universally better than a bunch of uga duggas.
For serious folks; from the manual
SPECIFICATIONS
Torque Specifications, F-150, F-250 4x4 And Bronco
Description Nm Lb-Ft
Shock Bracket to Axle 26-34 19-25
Radius Arm to Axle, Upper Stud, Bronco, F-150 4x4 326-352 240-260 (Hand-Tighten)
Radius Arm to Axle, Lower Bolt, Bronco, F-150 4x4 434-461 320-339 (Hand-Tighten)
Front Spring to Axle U-Bolt, F-250 4x4 115-163 85-120
Front Spring Assembly to Hanger Bracket, F-250 4x4 149-201 109-148
Front Spring Shackle to Frame, F-250 4x4 203-285 150-210
Front Spring to Shackle, F-250 4x4 115-163 85-120
Radius Arm to Bracket, Bronco, F-150 4x4 113-153 84-112
Spring Retainer to Spring Seat and Shock Bracket, Bronco, F-150 4x4 18-24 13-18
Lower Spring Retainer to Radius Arm, Bronco, F-150 4x4 94-134 70-100
Front Shock Bracket to Frame, F-250 4x4 71-100 52-74
Front Shock to Shock Bracket, Lower, Bronco, F-150 4x4 60-80 44-59
Front Shock Absorber Stud, Upper, Bronco, F-150 4x4 34-46 26-33
Front Shock to Front Spring Plate Spacer, Lower, F-250 4x4 60-81 45-60
Front Shock to Bracket, Upper, F-250 4x4 71-100 52-74
Front Suspension Bumper to Bumper Bracket, F-250 4x4 30-41 22-30
Front Shock Bracket to Radius Arm 34-46 26-33
Bumper Bracket to Frame, F-250 4x4 77-103 57-75
Front Suspension Bumper to Upper Spring Seat, Bronco, F-150 4x4 17-23 13-16
Radius Arm Pivot Bracket to Frame, Bronco, F-150 4x4 104-148 77-109
Stabilizer Bar Link to Spring Seat, Bronco, F-150 4x4 72-108 53-79
Stabilizer Bar Link to Stabilizer Bar, Bronco, F-150 4x4 72-108 53-79
Stabilizer Bar Retainer to Bracket, Bronco 34-46 25-34
Stabilizer Bar Retainer to Crossmember and Mounting Bracket, F-150 4x4 34-46 25-34
Axle Pivot Bracket to Frame (Horizontal) 88-118 65-87
Axle Pivot Bracket to Frame, F-150 4x4, Bronco (Vertical) 103-149 75-109
Axle Pivot Bracket to Frame, F-250 4x4 (Vertical) 149-201 109-148
Radius Arm Bracket to Axle 213-287 157-211
Torque Specifications, F-350 4x4 With Dana 60 Monobeam Front Drive Axle
Bumper Mounting Bracket to Frame 76-104 52-74
Bumper to Mounting Bracket 30-40 22-30
Front Shock Bracket to Frame 68-92 51-67
Front Shock to Shock Bracket, Upper 60-81 45-60
Front Shock to Spacer Plate Bracket, Lower 60-81 45-60
Front Spring Assembly to Shackle 163-203 120-150
Front Spring Assembly to Spring Bracket 163-203 120-150
Front Spring Shackle to Frame 170-230 126-169
Stabilizer Bar Link Assembly Mounting Bracket to Frame 34-46 26-33
Stabilizer Bar Link Assembly to Mounting Bracket 70-100 52-73
Stabilizer Bar to Link Assembly 21-33 16-24
Tie Rod End to Spindle Arm 77-103 57-80
Tracking Bar Assembly to Mounting Bracket 163-203 120-150
Front Spring Mounting Bracket to Frame 47-78 35-57
Tracking Bar Mounting Bracket to Crossmember 88-118 65-87
U-Bolt to Front Spring Cap 115-163 85-120
U-Bolt to Stabilizer Bar Mounting Bracket (RH) 48-68 36-50
Stabilizer Bar to Mounting Bracket (LH) 48-68 35-50
aggiediesel01
Houston, TX
For some reason the formatting that spaces the torque values away from the descriptions isn't posting so you'll have to know that the first group of hyphenated numbers after the desc is the Nm value and then the Lb-Ft are listed.
u2slow
bilge rat
Coastal BC
A lot of the time I go with std/recommended torques based on fastener size/types. Especially if the OE fastener is gone, and using generic stuff instead.
;Sweet:joker:
TahoeTom
S. Lake Tahoe, CA
Haynes manual for Ford trucks shows 120-150 ft-lb for spring assembly to hanger bracket and 150-210 ft-lb for front shackle to shackle bracket.
Alleycat
