D60 dually changeover kit.
Status
Not open for further replies.
Complete D60 changeover off a 1989 F350 dually for sale.
this changeover comes with DRW hubs and rotors but can substitute with SRW hubs and rotors.
steering linkage is not in good shape.
NO REAR BLOCKS INCLUDED ON THIS KIT.
what you will get.
D60 kingpin axle.
panhard bar and locating bracket.
steering linkage and pitman arm.
D60 leaf springs and U-bolts
front CV axle sized for E4OD trans.
transfer case output yoke for D60
$1500 FOB san jose.
see pics below.
kcconfq
Livermore CA
I am familiar with what it takes to swap a D50 for the D60, but I have to ask anyway. With a D70U rear and D50 TTB front would I be able to swap In the front after confirming gear ratios? I understand worn parts need to be replaced. Sorry if this is a rookie question. Ive been away from my truck for way too long.
you can run up to a 10% difference between the two axles. in reality, the 10.25 3.55 is a close match to the D50/D60 3.54 axles. your D70 would be a 3.54, essentially it would be a better match. also, another item most people don't take into account is tire sizing. different makes have slightly different size profiles. ideally, you need to run one make on all four corners. hope this helps.
homelessduck
I may be interested Calvin. Maybe we can work out a package deal on the axle and 4x4 zf5:D
So this axle is 3.54 gearing ?
nope. this is a 4.10 axle. I was just using the 3.54 as an example since 4.10 is dead nuts across the board.
sounds like you're gettin' ready for a big build.;Sweet
homelessduck
Well that thought was short lived. My wife put in her 2 weeks today. I expect things to be tight for a little while so I guess you can count me out.
compressionignitionrules
Bluevale ON
even 4.10s aren't the same........................dana 60 reverse cut gears are usually 4.09 ratio when you break it right down. 4.09/4.10 .......3.54/3.55 they come that way OEM anyhow .
those dually hubs are getting hard to find around here.
Status
