Custom Turbo Exhaust Manifold
Nickbf2504x4
ATV Racr-IDI Driver
Colorado State!
so what encourages the exhaust to go up through the turbo, when it could just flow out the header like it is suppose to? cookoo cookoo cookoo
EvergreenRanch
In Transition
SF Bay Area, CA
nope we have been over this one, find the thread about it here elsewhere.......HUGE issues with this design...plus metallugically cast iron and simple bar stock dont take too kindly to welding together. i can tig, mig, oxy, and thermite (one of the coolest things in the world to watch by the way) and i wouldnt even dream of trying to accomplish a weld of that nature.
82fordtruck
NE Kansas
I dropped a keyseater about a foot or two once due to trying to weld mild steel to cast iron. I was about 14, and I learned real quick why cast iron is so damn finnicky.
Now, I hate to get heat even near cast iron at work. We deal with it more than I'd like - but it's cheap....
I guess the cost of turbo's keeps folks from wanting to invest in a true cast exhaust manifold with the proper setup to do duals.
argve
Resident Fruitcake
Gwynneville, Indiana
If you were to plumb the other side up to that manifold the pressure would have only one way to go - thru the turbo. It's a neat idea none the less but welding on cast is a fine art that only a few can do reliabliy - I for one can't do it but have talked to a guy that can and he says that it's a real pain to get a good weld on it and then he doesn't trust it for the long run.
zigg
Victoria,Canada
I remember seeing a setup like this a couple years back. One guy had one on his truck locally, but it was only on one manifold. This guy was trying to flog it. It wasn't a custom job either, someone was making these...
If it was me, I'd probably be thinking more along the lines of something closer to a custom header type setup and run a turbo on each one and then "y" them just before the intake...
Then you could also have "true" duals"...
Zigg :)
tractorman86
Buckeye, AZ
TLBREWER said:
Never thought the design through. That's what I get for cruising eBay at 4:00 in the morning half asleep.
tom
hey that will get the best of anyone, but dont let it happen again!!! :backoff
:D LOL :rotflmao
tonkadoctor
none ya bidnes
:***: :confused: :rotflmao As poor as that design is you'ld be better off trying to install your stock manifolds upside down and backwards cookoo and then bolt the turbos to the top of them. It would look just as cool :draw and you wouldn't have to worry about the welds breaking.:mad: The just route the pipes through the hood like the pulling trucks.:thumbsup:
The passenger side manifold for IH S series truck applications would be the best candidate. The pipe connection leaves it at a very clean 90 degree angle. Don't know if it would fit upside down though.
RKOCH
Fellow Oil Burner
Yorktown, Virginia
We used to do this on our pull truck. I welded 3x4 box tube to ther manifold to mount the turbo on each maniflod and then put a crossover pipe between the manifold outlets. We never had an issue and they were glowing red @ the end of 300 feet.
