bulletpruf
Ok, so I have disassembled three engines - 6.9 (manual trans), 7.3 x 2 (both auto trans - a C6 and a E40D) - and have parts strewn all over the garage. I have rebuilt one 7.3 and it's going in my '87 CC DRW 4x4 F350 with a ZF-5, single mass flywheel.
The thick crankshaft spacer is only for engines with automatic transmissions, right? And the manual trans just uses a thin (1/8") washer/spacer between the crank flange and the flywheel, correct?
On a related note, I'll order SMF bolts from Russ to attach the flywheel to the crank.
Thanks
Scott
Thanks
Scott
