Coolant Filter Results! (After 5000 miles)
BrianX128
Pittsburgh
So, a while back I had searched and read through many a thread on this website and with the help of you guys I installed a coolant filter. I used the napa 4019 kit that can be had from amazon with the 4070 filter, I spliced the filter into the inlet side heater hose and used extra 5/8 heater hose from advanced auto to make plumbing it easier so I could put it where I wanted to.
The thread is going to be somewhat irrelevant without a brief history of the truck but I'll try and keep it to the important details. Just skip to where you see pictures if you want to see the results and obvious conclusion.
Truck is a 1990 F350 crew cab rwd ZF5, has 118k miles on it as of now. Truck had a pretty easy life, was owned by an older man in Pittsburgh who had a work truck he drove in winter so it got to sit on some bad days since it's a 2wd. Just mostly highway miles driving to work and towing a small trailer with stuff for his work. He passed away and like a lot of IDI tales you will see, it got to someone (the son in law) who had no idea what he was doing, put autolites in it for one thing and changed the trans fluid and put gear oil in it. Just the usual stupid stuff that proper research can cause but its been taken care of since. Original owner used motorcraft antifreeze with the motorcraft sca additive, as his records were in the glove box. Truck only had one batch of major repairs under the original owner as it got new rings and some other top end work right before the original owner had passed. The ford garage that did it also put an IP from a wrecked truck with 48k miles on it and it got injectors as well. Paperwork didn't specify where from so I'll assume it was from the same wrecked truck. It's at least nice for me to know I have new rings and that my IP isn't really at 118k, though I do need to time my truck at some point if the chance ever presents itself as I think it is just a bit retarded and so did some at the rally but it really runs good. Coolant and oil had always stayed in their respective homes.
So anyways, approached another oil change and had turned the heater on once a week to see if it was still hot to know if the coolant filter was still flowing well or not and noticed it had cooled a lot. Figured I'd take it off today and see what was going on and change it out.
So, I took the filter off in a zip lock bag. What came out looked a bit strange but I didn't think it was gonna be filter clogged worthy..
Well, that's rather gross. Lots of stuff that was floating around in there definitely got caught up in the filter. I know I could have flushed it and used fleet charge, but I'm a big fan of if it's working and doesn't leak leave it be. And since I could get test strips and vc8 sca additive and still be doing things correctly that was the route I chose, but this stuff I'm glad is coming out.
Another view of inside the filter housing.
In case you don't know about this install as well, here is a picture of all you have to do. The 4019 kit comes with a filter and all of the mounting and plumbing hardware. You can do the entire install with nothing more then a knife to cut your heater hose. Here's a picture of mine when I first put it in. I eventually made a piece of metal to mount it off the side of the fuel filter but that's honestly optional as long as you put it in a good vertical place where it won't interfere with other stuff.
But, here's a look into the radiator. Everything looks really good. Never thought it looked "bad" before but it's a way brighter and clearer green and the sca's tested perfectly yet again so that was nice to see. Put another 4070 filter on and we'll see what happens at the next oil change.
If you aren't sure if a coolant filter system would benefit you though, I wish I had a before picture of my fluid in the radiator but I would have never thought I had this much junk floating around in there.
I did. Just do this if your questioning it.
BrianX128
Pittsburgh
Added a picture of what the setup looks like in case there's someone reading this who doesn't know what the kit comes with and how easy it is to splice in.
I'll cut the filter apart after work today, though it is sitting outside so hopefully it doesn't rain and wash the crud away but it seems on there pretty good anyways haha.
BrianX128
Pittsburgh
Yuck
The Warden
MiB Impersonator
Fog Bless Pacifica (CA)
I remember getting into an argument a couple of years back with someone on here who thought that coolant filters were a waste of time and money. IMHO here's a very good argument refuting that...wow!
there's no argument on stuff that improves your vehicle. if they feel it's unnecessary...listen/read, then smile and move on quickly. :D
DaytonaBill
USA
I need to do the same... Trick is how far away from fuel filter using some angle iron...
Don't want to wrestle with replacing fuel filter with coolant filter in the way...
BrianX128
Pittsburgh
I left a good bit of slack in my hose coming from the block that way if I loosen the bolts on the fuel filter I can "pick up" the assembly and move it off to almost where I had it zip tied in my picture. I'll take a picture tomorrow of how I did that part. There aren't holes in the plate I mounted it in on the fuel filter, just slots /-\ kinda like that that the bolts on the fuel filter push up against so I don't gotta take everything apart just loosen them a bit to do stuff.
Kizer
Denton, Texas
Here's how I mounted mine. I went ahead with the Ranger vacuum valve as well.
BrianX128
Pittsburgh
4000 miles have came and gone.
Figured I'd post a follow up as to what happened when I changed it a second time.
Wouldn't have even needed to change it, so now I'm gonna let it go three oil changes before changing it again and see how that does. Was surprised how clean it was after the mess it caught the first time, but very happy with the results.
DaveBen
Ukiah, Ca
I put a coolant filter on my 2004 F-350 and the first filter change found all sorts of junk in the block that had not been flushed by Ford prior to assembly. Clean ever since. Good move Brian!
Alleycat
