Clutch went out?
pwjackson
Saint Paris/OH
Ok my clutch went and it went with no warning. I am thinking its the linkage, anyone have any thoughts.
marblecrusher
Van Alstyne, TX
well get underneath there and take a look, did it quit goin down the road, did it make a certain noise when it quit? A little more of a description as to what happened would help us help you.
-Jordan-
The above questions need to be answered before we can help you determine whats going on with your clutch.... If the peddle just fell to the floor then your linkage has fallen off... If its been slidding more and more as you drive the rig then maybe its worn out or needs some adjustment... So please help by answering these questions.
Sycostang67
Scooty Puff Junior
Kuna, ID
Going off the truck in your sig, you have hydraulic linkage. Either the master failed, the slave failed, or your hose burst. You need to cough up some more info or crawl under there and look around.
bigblue85
Vallonia/IN/USA
happened to me pedal just went to floor and couldnt disengauge and it was slave. master and line and clutch fork could all take part in failing too. but clutchwould slip a while before it fully went out. unless it was being ***** and just broke or fell apart/cracked or whatnot
pwjackson
Saint Paris/OH
Well I did some checking and the master had very little fluid in it. Could not see where it was leaking out.
hesutton
The Anti-Anderson
Bowling Green, KY
The slave cylinder or hose has likely failed and you are losing fluid there. What did you see when looking under the truck at these parts?
Heath
pwjackson
Saint Paris/OH
I didn't really get under there, the truck is at my friends shop. He looked and could not see a noticable leak. He should get it up on the rack today and have a better veiw of whats going on.
hesutton
The Anti-Anderson
Bowling Green, KY
Yup, you gotta have a good look at that hydraulic clutch system. Something has failed.
Heath
MadScientist
