ryanecvbrown
Credo Quia Absurdum
Mornin everyone! I'm acquiring an '84 F250 XCLB so I can fit my whole family in the truck for camping, errands etc. Current truck is an '87 SCLB 6.9 ZF. The '84 is an auto and I'll be swapping most of everything from mine into the '84. I'm familiar with the dash layout and know of a few differences with the pedal brackets '80-'86 vs '87-'91. I can't find a clutch pedal swing bracket anywhere and don't wanna swap my dash into the "new" truck. Anyone know if the '87 pedal bracket will align with the steering column? I know dash mods and some fab work would be necessary. I also know the firewall bolt pattern matches but my bracket is wider at the steering column end and prolly wouldn't clear the dash structure without modification. Would it be long enough to reach the mount on the steering column? I wouldn't mind swapping my column to make this work if the offset from firewall flange to the column is the same. Thanks in advance y'all!!
