RSchanz
So, brought the truck to my mechanic to look into my head gasket issue and coincidentally on the way in turning the corner the truck kinda ground when downshifting to 3rd, didnt think much of it. When getting ready to pick the truck up mechanic called me and asked if I ever had issues with the clutch, I said no.
He ended up saying that his guy topped off the slave cylinder and I should monitor situation. (I dont think he bled it properly, heard him say he just pumped the clutch like 20 times - side note). He said its probably not the master cylinder because it would leak onto my foot. Drove the truck home and by the time I got back I could barely shift it into gear especially without grinding. There is also very little pressure on the clutch so I'm assuming a fluid leak somewhere. At the moment the head gasket is leaking when hot and onto the slave cylinder and dripping down so it's hard to pinpoint if its leaking DOT fluid or coolant. Any ideas on trouble shooting? Could the coolant be leaking on the slave and creating this issue somehow?
This type of issue is new to me so bear with me, thank you!
