I work at a salvage yard, I already have a factory downtube, a full 5in exhaust from a truck, and have avaliable all the turbo stuff on an engine, (pedestal, intake, exhaust cross tubes.
well the stuff wont exactly swap over but with modifications it will, when i was going to do the psd turbo swap i found out that anything that went to the turbo on the psd would come in use cause you can modify most of it to make it work, i plan on putting a 94-97 model non gated psd turbo probly with a 1.00 fast spool exaust housing and see how far i can lift my heads
