CCLB 2x4 DRW- 4x4 SRW With PMF RSK
6.9poweredscout
Bleeds IH red...
Northeastern Pa
Finally did it!
When I got the RSK kit.
On pre '92 trucks it took some cutting so the best route was to burn it on!
99+ x code springs
Bilsteins
Parts rig for the shackle brackets and various other pieces
use 3 to make 1 good one!
Cleaned and painted
Last tow as a Dually. yes that's my old stroker, Benton and I are swapping parts around!
Scrap. If you don't have an air chisel with the tools to chisel rivets, it'd be a huge pain. I had the ols stuff out in NO TIME.
6.9poweredscout
Bleeds IH red...
Northeastern Pa
Off with the bed!
Drilling, drilling, and bolting....
Pitman arm difference...
Oh baby!
Needed supplies...
Brandon's dad cleaned and painted the frame for me!
Gotta get the bags back on it.
All in all it rides nice, the steering wanders a little, when I turn the wheel the tie rods twist before they do anything. may jusy go full high steer. Need to get in the front shaft and get the sway bars connected, anyone know if the 2x4 and 4x4 sway bars are different?
laserjock
Almost there...
Front or rear? The front sway bars on a 60 tie into the axle and mount between the rear spring hanger and bump stop.
laserjock
Almost there...
As a side note, if you'd like to part with the quarter windows in that donor truck shoot me a pm.
laserjock
Almost there...
I meant the windows in the extended cab. But no worries. So you don't have a 60 sway bar set? I can give you a parts run down.
laserjock
Almost there...
So here is the sway bar.
Here are the brackets that mount it to the axle. The muffler clamp looking thing goes on pass side of the pumpkin. The other one bolts to the drivers side I think.
The links go up to the frame to these brackets behind the bump stops and before the spring hanger.
Mine aren't all cleaned up yet unfortunately.
That should be all of it.
6.9poweredscout
Bleeds IH red...
Northeastern Pa
I have the 60 sway bar, i need the frame bbrackets. The rear one i have wouldn't reach the rear axle with the links hooked up.
laserjock
Almost there...
Oh, you need the rear sway bar stuff for the sterling? My 250 I don't think had one. This is the one off my 350 parts truck that is going in my truck..whatever it is. For reference, here is the sway bar.
And bracket
laserjock
Almost there...
Were do you get the kit from? Would like to do my truck
My stuff came off an F-350. 90 that I pulled the dana 60 and rear axle from. I have no idea if it's available from the aftermarket but some kit probably could be made to work.
6.9poweredscout
Bleeds IH red...
Northeastern Pa
It's the PMF kit. Everyone recommends v code springs for a soft ride. I have x code and they're super soft. Almost wonder if i should run dual shocks. Hoping with the sway bars it'll tighten things up a bit.
6.9poweredscout
Bleeds IH red...
Northeastern Pa
Anyone have pictures of where the rear sway bar links attach to the frame? Wondering if i can use the 2wd bar and make links.
LCAM-01XA
my very own hell
Sure you can. The 4x4 and 2wd bars are the same, it's just the 2wd links are S-shaped and bolt to the outside of the frame rail, while the 4x4 links are straight and bolt to the bottom of the frame with brackets. Cut the 2wd links in half in the straight section right above the bar and extend them as needed. IIRC 1/2" black iron gas pipe is about perfect for the job, this is not really a high stress area that requires DOM tubing for the extensions (altho if you have DOM of proper size by all means use that).
Same idea can be applied in the front if your existing links come up short. Not sure where you can get the F350 brackets there tho, I'd probably just make my own if I needed them. Or try running rear links on the front as well (extended as needed) should be enough space to sneak them in between the springs and the frame, especially with the extra clearance the RSK setup gives you.
Out of curiosity, why did you go to SRW? Kinda limits what you can haul, 6100lbs is what a pair of single wheels maxes out, in comparison the DRW setup cap is 8800lbs.
laserjock
Almost there...
Last picture I posted. The three holes above it are the shock mount. The holes in front of it are the front overload bumper location.
