EMD_DRIVER
Say what?!?!
For your viewing pleasure, are the glow plugs I removed from the 99 dually this evening. I've been having to plug the truck in, since it started cooling off. A quick OHM check, said that three of the eight were still good. I checked them as I was removing them and found that only one was good! Can you spot the good one?
They are in order.. 1,3,5,7,2,4,6,8
Only number three, was still good.. I ended up with seven bad ones!
