can anyone shed some light??ve pump/fuel probs..
cfm
england
hi again, to all,
right, my eternelle ve pump probs i thought were over..
new pump and injecters from wrecked truck, fitted, checked gear timing(woodruff key down front case= strip it)
all ok there, fitted and guess what?? she still wont start..
well a couple of cans of easy start she will, holds tickover, cannot get more than 25 percent acceleration, then stalls..
re easy start to keep a tickover etc..
bled injectors several times- fitted brand new racor fg500 filter unit on suctoin side...still no go...
farked about with the fuel pressure screw... does next to nothing
re checked timing with info from bosch center..ok...
re bleed etc....
is it a air leak prob???
question- the lift pump seeems ok, and pumps ok....
could this cause the symptoms??
i tried with a fuel injection electric fuel pump--nothing aswelll
im gonna being mucking around again..
anyone want to help via msn messenger????
contact me PLEASE
[email protected]
3 months- still broken down....
im running out of patience!!!!!!!!:mad::mad::mad::mad::mad::mad::mad:
MadScientist
