Good, it's all going to be easy then, excep MAYBE the driveshafts. We'll have to see. Best of luck to you. My swap became a nightmare because I was not competentto do the work myself at the time so I paid a real mechanic friend with a nice shop to help out. My donor tranny had a bad gear and idler so I had to find another 4 speed in the junkyard. Also I was bound and determined to not use the hydraulic clutch system these trucks had so I paid him a good deal of money to modify my bellhousing to accept a mechanical clutch system from an early 80s F100. The good part about that is that I never have to worry about a MC or slave cylinder leaving me stuck on the road the bad part is it was a lot of detail, a lot of labor and of course a one of part, so if it breaks that's not going to be very good. The driveshaft I believe on my truck had to be lengthened to work so I had a new set made (expen$ive) and I wound up having to pay to get it balanced at another shop plus fix where we screwed up by torching the carrier bearing off the driveshaft to replace it. Bad memories, but I am really as thrilled as I can be with the swap, I just much prefer driving around a manual and having the gasser tranny with the wide ratio its just asking for me to put mt Spicer brownie box behind it, but it's going to have to wait awhile I guess. Just had to buy tires.
