i noticed my TC was leaking fluid, so i replaced the tailshaft bushing and oil seal...... still leaks.
then i noticed that the case was cracked right under the drain plug boss, from the face of the plug to 1/2" toward the front. looks like i put too much teflon tape on it many years ago, hence oversizing the plug and then cracking the threaded boss all the way through. should have used pipe dope instead of teflon tape!
i'm going to try putting RTV on the inside of the crack, RTV in the threads, and JB weld on the outside. its been draining for 24 hrs, going to clean it with brake cleaner and rough it up so the glue will stick.
does anyone think this has a prayer of working, or am i going to pull that case and replace the whole housing ?
welding may be an option, but i've never had much luck with welding porous castings impregnated with oil.
