burb-o-matic in the fleet.....
I was holding out for a 4door bronco with a IDI but this unwanted stepchild showed up. for a $1000, I couldn't go wrong. even if it blows up in a year, I will get one snow season out of it.;Sweet my kid is grinning from ear-to-ear. she knows ski slopes are imminent this year.
anyways....the specs.....
1985 GMC Suburban light 3/4t 4x4.
6.5t goodwrench replacement engine.
Banks 6.2 turbo kit.
THM700 trans.
D44 front/Corp semi-float rear.
interior not tore up;Sweet
barn-door butt section.
itsacrazyasian
residentcrazyasian
boca raton, fl
Dude that thing is sweet! I had looked for one of those for over a year.
Wound up with a 96 2500 4x4 TD. The 6.5 easily out performs my 6.9 or 7.3 in the fuel economy department.
thanks guys;Sweet
there's a couple '95 and up burbs around here, but I refuse to deal with the DS4 pump system. creature comforts are alot nicer in the newer ones tho.
my gray CC dually is getting some much needed rest with this one doing commuter duties. the wife likes the fact the interior isn't tore up. I've owned a few burbs that look like a hungry rottweiler was locked in the truck.:eek:
argve
Resident Fruitcake
Gwynneville, Indiana
Damn Kal... you boys out there have some great looking "Junkers".... That thing is worth twice to three times that amount here in the rust belt.
most everyone wants "new" out here. If the late model DS4 burbs were more reliable, they would still hold their value. If you want hi-cap family hauling, it's either a burb or a van. vans are a no-go with my bionic rebuilt legs due to the cramped footwell, so it's a burb or a fourdoor bronco. burb won this time:D
this one is looking for a home......
84 gmc 3/4 ton suburban 6.2 diesel - $500 (los gatos)
Date: 2011-01-05, 12:32AM PST
Reply to: see below
This truck should be viewed as a project only. It is currently not running due to air in the fuel system. I havent owned this thing for more than a month, I bought it intending to use it as a tow rig project but i've since decided its more than i have time for and am focusing on my offroad projects. The main attraction to this thing is the smog exempt title which is huge as long as the California air resources board exist. This rig has NO SMOG ever.
Price...
1000 as is
500 w/o transmission/transfer case
Acceptable partial/full trades/i add cash trade items include but are not limited to...
winches,onboard air systems tanks or compressors,one ton gm axles, Tubing bender, Welder etc...
Pictures....
http://s40.photobucket.com/albums/e205/superman2054/84 gmc suburban/?albumview=slideshow
Specs
206k unconfirmed miles along with a crapload of receipts from person i bought it from, Again i havent even had this thing for a month, Its just not the right tow rig for me. And im looking to get out of it
engine=6.2 diesel with cracked block welded in 2000, Newer starter/flex plate
transmission=th400 rebuilt 21k miles ago unconfirmed
transfer case=np208
axles=dana 44 8 lug front,14 bolt semi floater rear
40 gallon fuel tank with stock skid plate full of diesel
Contact info...
cell=408-416-8535
9am-9pm only, Texts are preferrable unless you have something that requires a full discussion
  • it's NOT ok to contact this poster with services or other commercial interests
PostingID: 2144491955
justcuz
Alta Loma, Ca. 91701
I noticed you have referred to the front axles in these Suburbans as Dana 44's. Actually they are corporate 10 bolts. They are roughly the same as a Dana 44 in the strength department, but do not have the aftermarket support Dana 44's do. Everything from the knuckles out are the same as a Dana 44 though and interchange.
you could very well be right there.
I've been lucky and have found Dana 44 stuff to keep my trucks running.
irregardless, we can certainly agree it's some pretty light duty stuff, but this truck is not being used for hardcore off-roading. the worst it is going to see is muddy, slushy pavement.
justcuz
Dana 44's are easy identified. They have a 44 cast in the web of the housing in the front bottom, usually on the long tube side. The cover is more octagonal than a 10 bolt also (the 10 bolt being almost completely round).
so what's this one then? 10bolt?
justcuz
Your welcome. I've learned more about Ford IDI diesels here in 2 days than I really wanted to know. Since I am a big Chevy guy (except diesels) I thought I would share some of that knowlege. The Ford/IH idi seems to be the best choice for me to purchase an inexpensive diesel truck for off road use. Thanks to this forum I have come to that conclusion.
mitsu tractor
