Jeff
If you are sitting at a stop and apply pretty good brake pressure, the pedal will eventually go down. As long as it doesn't go right down and the brakes don't hold. It sounds like you fixed that problem.
I agree with the others on rear brake adjustment. Unless you did it yourself or were present when it was done, I would not necessarily trust that it was done correctly. Very simple and easy to do incorrectly. I know I have to do both my '91's periodically and it is surprising how much difference it makes in pedal feel. I didn't believe it at first.
As far as the MC is concerned, I use Napa parts a lot. However, it is getting to the point that even some of those parts are not any better than the other suppliers. That being said, If I'm not buying the part from Ford or a custom/specialized supplier, Napa is where I spend my money (way too much of it
Tom
