brake problems
paygie94
Middleburg PA
my 84 ford f250 6.9 started having weak brakes, then just recently started getting brake fluid inside the cab coming off the brake pedal. replaced master cylinder tonight and now im really getting a puddle inside the cab and I cant get any pressure to the calipers or the rear brake cylinder and have no brakes at all now. what am I doing wrong? help please.
hallgren87idi
gold bar, washington
maybe the vacuum booster took a crap? the one went out in my '80 ford fairmont, and when i pressed the brakes they would hardly work and it would make the car run like crap. i dnt know how to test it but that would be my guess, idk
chris142
SoCal
Have you been adding brake fluid? Normally a bad master wont fill up the booster like that unless you have been refilling the master a whole lot.
dirtbiker
Illinois
We just had the same scenario with our 79 powered 6.9. In researching it, a lot of what I read suggests that often times the booster and the master fail at the same time. The seal in the booster fails, and the vacuum from the booster sucks fluid past the master cylinder seals. Brake fluid is corrosive and exacerbates the diaphragm failure inside the booster unit. It is common enough that they sell re-manufactured booster/master assemblies, at very reasonable prices.
chris142
SoCal
Adding fluid to the system filled up the brake booster since the master cylinder was bad. now you need a booster and a master
Say what?
If that was the case then why would it work so well with so many different types of materials? Let me look at this ...Aluminum for master cyl, oh and plastic too, then steel for brake lines, rubber for seals and flex lines, so forgive me I'm just not seeing the fact as you put it?
Yes it will remove paint nicely but in regards to corrosive, I'm just not seeing that.
Please explain/prove this so I can learn about this nature of brake fluid.
Thanks
dirtbiker
Illinois
I can't find the Bendix TSB I found last week when I was going through it, but it stated that (specifically) the diaphragm and valving in the booster are damaged by brake fluid. They cited that as the reason that often times the push rod seal begins failing, causing the booster to pull brake fluid past the master cylinder seals, and that the brake fluid in the booster causes a failure of the booster diaphragm. Since I received my new booster/master unit from a place that does not require a core (Amazon), it sounds like an autopsy is in my future.
chris142
SoCal
Why are you taking the booster apart? There's no user serviceable parts in there. Any auto parts store will have a new booster and master ready to go at a very reasonable cost
thx997303
utah
Some people aren't content knowing what the problem was, but also how and why the problem occurred. I usually do the same thing if I don't have to return a core.
I'm naturally curious.
dirtbiker
Illinois
You got it, thx997303. I already sourced and installed a booster/master. Since I do not need to do anything with the core aside from throw it away, I want to see if the failure appears to have occurred in the manner suggested in the TSB. Kind of a forensic experiment.
ntjapkes
