wwwabbit
Mmmmm Diesel
Woohoo! I got it running! I just the diesel motor... ahhhh...
Anyway
So, I have done just about everything on the brakes.
New: lines, front pads, calipers, disks, rear wheel cylinders.
When the truck is off, you press the brake pedal and it goes down, and comes back up to full height.
When the truck is running, you press the brake pedal and it goes down with much less effort (so I know the booster is doing it's job) but the pedal won't come all the way back up, it stops about 1/2 way. If you pull up on the pedal it will come back up, it does not take much effort, but it does take some.
If I pull out the vaccum hose, it does not do it. So, my thought is that something is wrong with the booster, or the master brake cylinder (which I didn't change)
Hummm, I just thought of something. Could some air in the master cylinder cause this? It did drain out most of the fluid while I was changing all the brake stuff. I didn't take the master cylinder off and blead it, just added fluid and blead everything else (including the ABS thing for the rear)
Anyway
