fordf350man
Yes, someone in the know told me that also about the newer cars and trucks. Pushing the piston back pushes all that old rusty fluid back up in the complicated abs valve system and can cause it to fail. After I was told that, I started to also do it on these older trucks. It's doesn't hurt the master, but our systems can also do without all that rust being pushed back up in the system, and also if you keep the master topped off, it will overflow and make a mess unless you release the bleeder and let the excess fluid come out there. By the time you do that, and then bleed them a little bit from the master, you should have mostly new fluid in the system, getting rid of that old stuff.
you should never add brake fluid unless you are flushing the system or refilling because of a leak, the brake system is a sealed system and any time it is open to the air it can absorb moisture and contaminants witch will cause issues, there is no need to open the bleeders to push the pistons back in, if there is crud in the system it needs a flush, a properly maintained brake fluid system should not have any contaminates, you get the rust build up because people open the master cylinder to add fluid and at that point it absorbs the moisture witch causes the the rust to form inside the system, the fluid level is actually the wear indicator for the brake pads and shoes, when the level gets down to the min mark that means the pads are getting low and its time to change them, like you said when people add fluid and then press in the piston it overflows and that's because the system was over filled, if it isn't overfilled and you change the pads when the pistons are pushed back in for new pads then the fluid level will be at the max mark, another thing people to is push the little boot back in on the cap for the master cylinder and your suppose to leave that popped out, with that popped out it makes a smaller space inside the master cylinder to be filled with air so less moisture can be absorbed into the fluid, as long as the system stays sealed there is no need to flush it every year, i would do every 50,000 miles myself, GM recommends at 100,000 miles for a brake fluid flush so do other manufacturers
pumping the pedal on while bleeding brakes isn't a bad thing, has never failed me or taken long, it allows pressure to be built up in the system to force air out, just like a pressure bleeder, doing that helps to eliminate air in the hard areas like ABS modules and valves and things of that sort, i now have a pressure bleeder that applies the pressure to the master cylinder and then its a one man job to go to the bleeders and open them, but having someone pump the pedal is the same thing, build pressure to force air out, not trying to start any battles here just my two cents i know there are many different ways and theories to do this, as long as it gets done who cares
