Body mounts
asmith
Atascadero, Ca
I am getting ready to replace the body mounts on my truck. Looking around it looks like the polyurethane ones are all you can get, except for a set from S&B that are silicone, but they are about twice the cost. the energy suspension ones are $239 and the S&B ones are $449. They look really nice and come with shims and stuff, but not sure if they are worth it. Anyone have any experience with either of these good or bad?
chillman88
Central NY
I have no issues with my urethane body bushings. It might be more harsh but I didn't notice a ride quality difference from my old beat rubber mounts.
I have heard good things about the SB Silicone mounts, but I can't afford them. A huge bonus though they come with new metal parts if I remember correctly. I'd like to try them someday.
Rdnck84_03
Kansas
If you're hardware is shot, that could be worth the extra cost. I probably have about 20 hrs in building all the hardware to install the new poly mounts on the '84 k10 I have been restoring.
James
chicken bones
Docker
PittMeadow B.C.
I did the S&B Silcone , very good product, comes complete with all hardware. I had to zip cut some of the old bolts. Expensive but very nice ride, I recommend .
chillman88
Central NY
So you are saying they made a noticable improvement in ride? That's good to know.
asmith
Atascadero, Ca
Thanks for the replys. I am already spending a bunch of money so I dont really want to spend another $500, but if they make a difference it might be worth it. I just dont want to buy the polyurethane ones and be bummed with ride. Everyone always says how stiff they are compared to rubber.
It looked to me like the Energy suspension ones come with hardware, but maybe not. I will double check.
1mouse3
il
I have the 4.4123g polly set from energy, and comes with all the hardware. My truck is not yet assembled, so cant say how they are with ride. Then again I have f-super springs, so have a stiff ride anyways. I chose polly just for ease of install and removal, so am not wasting time now or in the future to service. I also have the polly busings for my front leafs and so far not given issue.
chillman88
Central NY
Yeah you're right it does look like it comes with the hardware. I used the Prothane mounts and they require reusing the old hardware. I hadn't noticed the difference between manufacturers.
rvitko
Manchaca TX
I used the s&b silicon mounts. They also include a puller tool. I can’t really compare to anything else, mine were beyond shot before the change, even with the puller I had to burn/sawzall one out in the back. I used poly on a previous project (M-1009 military blazer) and didn’t care for the ride. It does come really complete, really nice shims and hardware. I hemmed and hawed on the cost as well but it’s a big enough PITA I didn’t want to do it twice.
asmith
Atascadero, Ca
I hate doing stuff twice too. Thats why I am going back and forth on it. I dont want to get the poly and then hate it.
Noiseydiesel
Hillsboro, Ore
I just did a set of Poly on the '94 cc dually. Poly is cheap enough from rockauto. About $125/130. I got a 3 inch pipe from an exhaust shop with a length of All thread (1/2-13?) for the center. I found a chunk of 3/8 flat steel to drill through and then picked up 3 nuts. two at the bottom and one to run the plate up on to pull out the lower bushing.
I also found it easier to remove the bolts if you take a wheel and cut off the bolt hanging down. Easier than trying to remove rust to get the bolt out. Energy kit has new hardware.
This has yet to get on the road and with the front reverse shackle kit ride quality is destined to change anyway.
03wr250f
Hamilton/Montana
S&b hands down
Lifetime warranty, they have flex/give for when the frames articulate (buddy popped his windshield from the cab flexing the truck hard with poly mounts)
And the biggest thing for me, they come with the puller tools to remove the old bushings
Slicknik
Burbank, CA
I bought the energy suspension kit 2 years ago works fine , made a puller setup and it took half a day
Removes the body roll and raised the body almost 1/4 of an inch
Make sure you apply that silicone grease otherwise in 3 months you’ll be squeaking louder than the hotel bed on a Friday night
JU57US
