As afar as the cooling system, there is a ball in the t/stat hsg that is "supposed" to bleed the system.....if the ball is pitted/stuck etc... it will do no good, SO...being "old school"
I have allways stressed that to properly bleed the system, fill as normal till safe to start....loosen the highest hose clamp in the system-usually the heater hose at the core{firewall} and that will purge the system of air.
Water pumps will not move liquid if there is air trapped in the system!
OR if you have a flush and fill tee, you can bleed the air from there.
Oil...just fill your filter of choice- preferably a Motorcraft FL 1995
about 3/4 full. This will take a couple trys as the media will saturate.....don't forget to wipe some oil on the gskt! Start with 9 qts in the pan and top off as nesc...{I forget the exact oil capacity of the IDI- sorry}
Don't bother filling the filter full....you will only prime your armpit when you try and install it
Fuel- if you are using the stock mechanical lift pump...fill the fuel filter with fresh diesel, spin on and it will be nesec to use the starter to purge the system....
Loosen all fuel lines at the nozzles and spin the eng over---
!!NO MORE THAN 30 sec with a couple mins cool down between trys.!!
If elec
just install the filter, energise the fuel pump and crack the line at the inlet side of the IP...you will still need to loosen the lines at the nozzles however to purge.
Snug the lines when you see fuel spurting out.
By now the oil gallies will be full enough so that when it does catch and sputter, you can slightly speed the eng up to help move fuel thru.
There will be ALOT of white smoke...this should dissapate with a n air free system
It will prolly be nesc to loosen each fuel line individualy to further purge and see if that particular cyl is firing.
It may take a couple tries and my way surely isn't the best but I've had my hands in quite a few diesels and you would prolly chit yourself if you saw my way
Hope some of this helps
