I've been following this forum for a couple years ever since I bought my truck, and I must say I've learned a lot from all of you without even having to create a new thread. But I'm kinda of stumped on this problem, if it even is a problem.
A little background on the truck first. It's a 1993 7.3 IDI NA. I bought it 2 years ago when it had around 170000 miles on and didn't run the greatest. I installed a new dynomax exhaust system shortly after I bought it. After driving it a few thousand miles it began to blow white smoke terribly at idle and deceleration, and was very difficult to start if I'd go into a store for a half hour or so. So after reading many posts on here I determined I needed to do a fuel system overhaul. I bought new BB injectors, return line, and a MINI moose pump from Conestoga and followed his very detailed installation instructions. After installation I rented a meter from icanfixall and timed at 9.5 and the truck ran better than I had ever hoped for.
The truck ran great for the first couple hundred miles after installation, but I noticed it started to blow black smoke lately more than I thought it should. I only have about half a pedals worth of travel before I can hear the motor change its sound and start to blow black smoke, which happens a lot driving through these hills of WV.
I'm not sure if this is really a problem, but I don't want to hurt my fuel mileage or wear out the pump and injectors prematurely. Could I possibly need to adjust the timing a little bit, or maybe turn down the fuel on the pump? Any help would be greatly appreciated!
Sent from my SAMSUNG-SM-G870A using Tapatalk
