Biodiesel Reference
Status
Not open for further replies.
Thanks to member Whitmore for providiing this list of compatible or not so compatible materials when using Biodiesel. Let this list guide you if you modify your truck for Biodiesel use. - Mel
Biodiesel and compatibility issues with fuel delivery components
I got these off a couple biodiesel sites.
SAE 30R7 is the most common fuel hose
SAE 30R9 is replacing those at the stores and will handle biodiesel at B20-B50 no problem.
Non Compatible Materials (B100)
Elastomers:
Nitrile Rubber
Polypropylene
Polyvinyl
Tygon
Behavior: Elastomers not compliant may degrade, soften, swell or seep from connections. Typically this only becomes an issue in vehicles built before 1993 which have older rubber hoses.
Metals:
Brass
Bronze
Copper
Lead
Tin
Zinc
Behavior: These metals can accelerate oxidation of the fuel and create insoluble gels and sediments when exposed to Biodiesel and air.
Paints: Most oil-based non enamel paint will be degraded by Biodiesel. Spills should be cleaned immediately with soap and water.
Compatible Materials (B100):
Elastomers:
Teflon
Viton
EPDM
Fluorinated Plastic (i.e., Fluorinated Polyethylene, Fluorinated Polypropylene)
Nylon
Polyethylene (HDPE)
Silicone
Behavior: These materials can be used to transmit and store Biodiesel, this includes “red plastic” gasoline cans, polyethylene barrels and large plastic totes.
Metals:
Aluminum
Steel
Compatibility with B20:
No negative effects have been observed for elastomers and metals exposed to B20, which are compliant with petroleum diesel to begin with. Materials compatible with regular diesel should perform the same when used with B20.
Status
